Will it run Doom?
Hey after some digging in the OS of the IO6 i want to callenge myself to run an custom Aplication on the radio. For your Informationen all is Stock and no Hardware changes was made. Just Crosscompile Doom for the iMX6 cpu on the HMI 2.5.
This is just for fun and to see what ist posible.
Here the result:
  • Replies 22
  • Views 724
Can you provide more information? I investigated some time ago and only found this.
@Arbe_gtc tomorow i will write a littel Summery. The only Problem ist i need to disable the watchdog and i dont not know how.
i have it, but the HMI reboots..... i see the doom runing a little time
Yes that ist my problem too. Did you Compiled fbdoom? What prog did you kill to get acess to the screen?
fbdoom yes,
its running 2 minutes 23 seconds, then HMI reboots, is not a normal poweroff
Killing this processes LayerManager|prochmi|procvideo
This ist exacly what i did. I think there is an watchdog tomorow i will try to disable this
I'm struggling with the sound, but I can't get it to work. If I send this through the HMI console:
aplay -D hw:0,0 -f S16_BE -r 48000 -c 2 /dev/urandom --duration=10
I'm getting white noise through the USB, but I can't get Doom to have sound...
Did you conneced an usb soundcard? I would love to figuere out how to inject sound in the silverbox
Ha, that's some pretty cool stuff right there 😀👍.
No, the sounds of the hmi, (android auto, carplay, USB, aux...) are sended to the radio module vía most bus.
To enable USB Keyboard input and play it, go to:
/lib/ald/security_features/usb_hid
and execute the enable_permanent.sh file. restart HMI and enjoy
Keyboard will work in both usb port of hmi
Nice ;) and sound over most?
News:
Well...
OpenLara
Nice how did you Managed this? How is the sound posible?
Gemini.
The sound:
A. Dedicated Software Mixer
Sound Decoding (CacheSFX): Reads classic Doom sound lumps (DSPISTOL, DSOOF, etc.), bypasses DMX headers, and converts them from 8-bit unsigned to 16-bit signed linear PCM samples (int16_t), resampled to 22,050 Hz.
Real-time Mixing Thread (AlsaAudioThread):
We create a secondary thread with a pthread synchronized using clock_nanosleep(CLOCK_MONOTONIC).
Mixes up to 16 simultaneous channels in 256-frame blocks (approx. 11.6 ms per block).
Applies stereo balance (vol_left, vol_right) and saturation control (clipping at -32768 / +32767).
B. Direct Injection to ALSA Without Blocking
Instead of compiling external ALSA C libraries with heavy dynamic links, the thread dumps frames directly through a pipe (popen) to the system's native aplay utility:
aplay -q -t raw -r 22050 -f S16_LE -c 2 --buffer-time=25000 --period-time=5000 -D default
-t raw -f S16_LE -c 2 -r 22050: Indicates that we are sending raw 16-bit PCM in stereo at 22050 Hz.
--buffer-time=25000 --period-time=5000: Sets the buffer to only 25 ms with 5 ms periods, making gunshots and growls sound instantaneous with no perceptible delay.
-D default: Routes audio to the kernel's default ALSA device on the HMI.
and selecting the USB input in the menu i have the game sound
Hardware acceleration mode and fully working
Well, it seems possible to compile anything... PCSX-ReARMed.
And I’ve taken advantage of the "shop" to launch the applications. I still need to figure out how to publish applications to the HMI.
How did you get this with the shop? I thourd it is an webpage on the device.
Maybe the next step is to crack the update algo. to get new games via an usb stick
its an html yes, but you can call apps using python
  4. uglyoldbastard
blocked Arbe_gtc SAUL MASATOSHI pupu14 marcel_hack_guy Mikluha_Maklay WhiteAndBlue Shavkat Abrayev Opelinsignia1985 Adelin bekatsilosani Flash hassan77h exc11 crakavelli Truhnder BLKATSG alatka asd JBL_1989 ABOMAZEN
