Techline Connect
  • Views 597
I think you got banned sue to counterfeit MDI device?
Are you using original GM or Chines clone?
7 hours ago, ChevyPL said:
Кажется, вас забанили за использование поддельного устройства MDI?
Вы используете оригинальный GM или китайский клон?
The adapter has nothing to do with it. It's specifically for the VPN.
Just now, tejiera said:
Адаптер тут ни при чем. Он нужен только для VPN.
I contacted AC Delco and they told me that it is prohibited for use in my country.
Yeah, but if you keep using counterfeit adapter you will be banned too.
I have that problem too. I'm in the Dominican Republic and I can't use Techline Connect. How can I do it? I've tried several VPNs, but I can't find one that works, and I've already had one of my accounts banned.
The account must be created as EU account not USA, then there is no problem to purchase the licenses, but the price list is different than that for USA and vice versa.
Option 2 is to install Tuxler VPN and set the "residential" option.
19 hours ago, Check Engine said:
I can help. but internet input output speed need to be 150 mb/s
nonsense....
У меня китайский CM2 Pro, который не работает с SPS2. Он работает с программой GM DPS, но вы не можете предоставить мне файл DPS.
I have a Chinese CM2 Pro that does not work with SPS2. Он работы с программы GM DPS, но вы не можете программы мне файл DPS.
M Ch GMcars Emmanuel Koomson CapriceV regloops Ferd Monge Inam Ullah jjagel zeraek tan tan ChevyPL Enterlan tungnv93pt Ahmy simaservis jesus teran karolputowski Dennis bekatsilosani thxx
