Cannot program DPS archive
I build an archive for BCM module, same way I did other archives in the past via DPS software but when trying to program it, DPS says that the file is not a valid GMLAN archive.
The archive is attached.
ATS_BCM.zip
Solved by ChevyPL
  • Views 288
  • After checking the archive file, I can see that the file order is incorrect. Post the untouched calibration files you collected from the SPS folder.
Make sure you use the 7-Zip app to decompress each calibration file after you collect the files from SPS, before creating the archive.
Ahh that makes sense. The order is wrong. Thanks for pointing this :)
I will create new arch and if I get the same problem I will upload calibrations here
Scammer Esteban Bogarin Pelonlsx jjagel Robby Schrimsher scanman dt_precision mcOreos alialsayyed lbarbar hootydavis carfix whopa Martin Mendez marcel_hack_guy Transmissionguy ajdabeast greyworm Encrypted Owner ChevyPL John Stevens
