Astra k change vin and pin in ecm
New to this so go easy please ,I am looking for the easiest way out to change VIN and PIN on a used ECM .I have the pin for both ecms and VINs .Do i need archive files and where will I get them.Thank you all.
  • Views 387
  • John Stevens
    John Stevens
    You don't need any calibration files if you're using DPS...You can just create a utility file. The gist of the process is to unlock the module with $27 and write a VIN with $3B from VIT1. The pin is a
  • I have dsp and sps access ,its just I dont have cal files.If I choose "set mec to zero ecm" will that virginize the ecm.
  • John Stevens
    John Stevens
Hi there, I am new but have a little experience. Model and year, please!
What do you wanna do...
You don't need any calibration files if you're using DPS...You can just create a utility file. The gist of the process is to unlock the module with $27 and write a VIN with $3B from VIT1. The pin is a special $AE message using GMLAN Interpreter $25.
I suggest you read the GM Interpreters document and come back with questions from there.
re: the MEC is the Manufacturer's Enable Counter and a value of 0 means you need $27 to perform most functions.
regloops Thamer Mo edyjhu tungnv93pt ViCo2 Enterlan John Stevens bondarrenko Opelinsignia1985 Andrei Akhramenka stensin Jasper tobiasp chicking exc11 geku erwin Olmaxim ff Galaxie hassan77h
