Insignia 1.6 SIDI Turbo A16XHT, E39A ECU tuning files Stage-1 and Stage-2
professional ECU tuning files for Insignia 1.6 SIDI Turbo ECM-Acdelco E39A, engine A16XHT
Includes Stage-1, Stage-2 and original stock ECU dump file.
The tuning can be done via OBD port using an open port 2 OBD interface and the now free ECUF Flasher (Alex Flasher) software.
Using the Open Port 2 and the Alex Flasher software, the Acdelco ECU E39A took 1 hour 27 minutes to read/dump the ECU and 3 minutes to write the tuning to the ECU.
Cheap Open Port 2 Clone that works.
The now free ECUF Flasher (Alex Flasher) software.
ECU Specs
ORIGINAL STOCK
POWER: 170hp
TORQUE: 260Nm
STAGE 1 TUNING
POWER: 200hp
TORQUE: 320Nm
STAGE 2 TUNING
POWER: 210hp
TORQUE: 336Nm
ECU Tuning files
  • Views 2.1k
  • wallacethetechnician
    Good work
  • I don't have those files. I originally paid universal_r to install that app on an old laptop before it was free. Also those files have malware so be careful on which PC you install them on.
Good work
On 8/16/2021 at 11:00 AM, lehoang2312 said:
Hi. Troy
Can I ecu dump file with MDI 2 and DPS ?
Hi, no you can’t dump files with dps.
@troy Can you upload that files into cameraloops.com?
notovi
