Global B CAN L - H resistance
Hello, did anyone knows what resistance should to be between can L and can H on each modules at Global B? At example i got a Escalade 2024 and on the TCM (transmission module) i got a 100 Ohm, on the TCCM (Transfer Case module) 50 Ohm, ECM = 120 Ohm and its OK - like on the wiring diagram. I'll try to find lost comunication on the CAN1 and CAN2, when i make bypass on the TCM and TCCM i still dont have communication with others modules. Did anyone have a TCM and TCCM and can check the resistance?
  • Views 354
M Ch Kpeezy modx Jose P igotthekeys SHARAWI deadcode aboturky High tazman A61bk artur minasyan Chevyfreak penguin4170 corb OP crakavelli Wlw2 TunnerXP codebuilder
