2017 Silverado HMI module
I have a truck with IO5 radio that has a bad HMI module. Can I install an IO6 HMI module into it?
  • Views 585
  • Yes, If the navigation is not needed, there would be no need for an antenna.
It should be no problem.
You just have to attach a external GPS antenna.
I only need to attach a GPS antenna if I want to use the factory navigation correct?
Yes,
M Ch chicking acff Enterlan DrJerry krlitros tobiasp Mehmet Zeki Cengiz Eatable Thomas Crosbie
