GM BCM Pin code?
I need assistance with the BCM PIN code is that the same as the one retrieved when programming the keys on the scanner tool, or is it a completely different PIN for the BCM when reprogramming the VIN with the DPS file?
  • Views 547
Pin code should be  the same in all modules of the car.
yeah I was able to pull it using the Autel scanner
redcamaro jjagel slpshtbms connor Murphy notovi Ediagforcars High twinduct
