language
  • Views 593
I can activate different languages if the Cadillac XT5/XT4 uses an HMI 2.5 module.
Thanks for clarifying. If I understand correctly, HMI 2.5 was in early XT5 models (2017-18). Do you have solutions for newer models without HMI 2.5? Also, for models with 2.5, can I get the Hebrew language file via USB, or is it DPS only?
No, I don't have a solution for the newer models. Maybe someone on here can help with that. The languages are activated in the HMI 2.5 calibration files and then programmed using DPS. I don't have a USB solution.
maybe someone in the group has a solution for changing the language in the multimedia system for Cadillac Escalade, Chevrolet Silverado 2024, or Hummer EV?
palyt Shifty exc11 bekatsilosani Shane Guinn gsmik Tarzan drocars wdse aboturky leohaBY OLEH Mehmet Zeki Cengiz tan tan Zheny
