MATRIX LIGHTS ON BUICK REGAL
I have a 2019 Buick Regal sportback, this car has led headlights, headlight control module, and front windshield camera. I am trying to enable the matrix leds/glarefree highbeams. @a b on this forum has accomplished this on his 2018 regal tourx. I have used his custom BCM calibration file to enable the auto high beams in the BCM. I've installed a wire (from the bcm to the turn signal stalk) and the turn signal stalk with auto high beam switch. I've also used @a b's front camera calibration files to program my camera. The problem I'm running into is this. The xml file @a b has used to configure his camera will not work with my camera. I have used my stock camera xml file and enabled the auto high beams and glare free high beams. The system now activates and turns the high beam indicator on or off for oncoming traffic,streetlights,etc.. BUT, the high beams themselves do not come on when the indicator comes on. The camera xml file @a b used is an OPEL file that has had RPO codes and security info modified to work with Buick. It has more modification items than my stock file. Dps throws an error code as soon as it trys to configure a did item not in my stock xml. My camera is part number 84537122, @a b's part number is 84225592. Do I need to replace my camera to use this xml or is there a way to make my camera work with the system? Are xml files dependent on software only? If software only, this xml should work. I have attached the stock camera xml file and the one I'm trying to use. Any advice or thoughts would be much appreciated!
My stock fcm xml.bin Camera XML take 2.xml
  • Views 759
Shifty Robi_X exc11 Jordan Carter apetrushenko BRANDON BURDEAUX Keep learning AWD SPORTBACK drstraleman Ahmed Ali
