DPS programming error for ECM
hi everyone i have Chevrolet  Suburban truck 2007 i am trying to replace 2 calibration in ecm package with same model year vehicle when i try to program its giving me Paddingerror i think op-code 53 compare data step in the end of programming its showing me successfully programmed but nothing changed inside the calibration  i am attaching the log can someone please help me to solve the problem... thanks
ecm_sun_ban_ap3.zip ProgramLog.ecmsuburban.Txt
Solved by codebuilder
  • Views 1k
  • codebuilder
    codebuilder
    I'm guessing you're using a clone MDI?  Try this utility and see if it works. 12603266.bin
  • hi codebuilder when i double checked the archive which i am trying to flash it was same archive which already in the ecm so i changed 2 calibration which i want to change then everything is worked fin
  • Hi thanks for reply no it was orignal mdi 2 and i will try your file tomorrow morning and will report you back thank you
12603266.bin
hi codebuilder when i double checked the archive which i am trying to flash it was same archive which already in the ecm so i changed 2 calibration which i want to change then everything is worked fine and flashed successfully thank you so much
Adelin jjagel jouhndggdh danna_rfk simaservis Bandi rusty2009 gsmik Angel Valenzuela Aquino Jaydog John Stevens AWD SPORTBACK Lister Llanes
