Impala 2017 IPC bench setup
Hi all i am trying to communicate Ipc on bench with connected BCM and i connected power ground wires of bcm and ipc and low speed canbus wire and i can get controller info of ipc but in few seconds ipc display blank and again wakeup i can get controller info sometimes and sometime communication error can someone please share the info how can i setup the ipc on bench for dps thank you all
  • Views 480
  • Hacktacular
    Hacktacular
    Do you have the 12v to the run/crank pin as well. I believe there are 2 12v pins.
  • on bench i was missing 1 wire from ignition switch to BCM when i connect all ignition wires according to GM SI and everything  work fine
Hi thank you for your reply but it was solved
HMI_Regal choi Tyler Mygrant
