2019 Buick Regal ipc xml file
Does anyone have the xml file for 2019 Buick Regal IPC with the updated 4" cluster? It seems the xml file for the updated 8" cluster is on this website, but no xml for 4" updated cluster.
Solved by Arbe_gtc
  • Views 650
udd or uhs? and with info3 audio systems, correct?
I have this two
39208935 - Regal GS 2019-2020 UHS Info3.xml 39202533 - Regal 2019 UDD Info3.xml
Yes udd with info3. Thank you!!!
tungnv93pt bondarrenko Elviss Pereira Robi_X nev3r Enterlan Jordan Carter jjagel Keep learning Shifty QUSAY OSMAN
