2018 Yukon change from adaptive cruise to regular cruise
I have an issue with a truck that I did a swap in.  I took a 2018 Silverado that had a 5.3/6spd and swapped a 6.2/10spd into it.  I am running the 6.2 ecm/tcm with that vin.  Issue is its from a Yukon with adaptive cruise control.  So the cruise on my truck doesn't work.  Is there a way to figure out how to change it to regular cruise and get it to work?  I have the cal files from both ecm.
  • Replies 6
  • Views 733
  • I was able to get some help on here and found a vin that has regular cruise.  I will flash it later today and let everyone know.     1GKS2HKJ2JR333034
  • FYI.  I did figure it out.  I just had to install a 120ohm resistor on the canbus wires at the adaptive cruise plug.
Here is the ecm cal files from my original truck vin.  So regular cruise control.
12665853 12667480 12675190 12675312 12675371 12675461 12686263 12686587 12711165
Here are the ecm cal files from the vin I need to use in order for the tcm to work properly.
12665853 12667480 12675191 12675316 12675394 12675500 12686622 12689533 12711165
1GKS2HKJ2JR333034
Well that didn't work.  It must be in the harness then?  Here is the cal files for the vin without adaptive cruise.
kobrak16 Cleberson Santos Daniil_Ast veetdoc exc11 Beezer Last_Captain Rrmjn
