Buick Design of Infotainment in Insignia
hi all,
is there a way to change the design of infotainment (not the IPC) in Insignia to Buick Regal Theme?
thanks for a reply...
  • Replies 9
  • Views 705
  • To have the Regal theme on the radio, these HMI 2.5 files can achieve it.
  • The visual theme in HMI 2.5, comes defined in calibration 07. position 5F if you change this position and correct checksum, the theme changes.
1 hour ago, BraynV said:
hi all,
is there also something for Insignia B?
If I would like (for any reason) go back to original Opel Theme of Intelilink, is it possible? Would I just use this again?
Yes, programming the HMI with GM SPS using your Opel VIN will restore the theme to its stock theme.
you can rollback any change simply loading the original calibrations. Are only configuration parameters.
so if I use this calibration file, right? ... it would be back the classic Opel. Nothing else needed, right?
is there any such solution for Insignia B?
try to get your calibration files
and play with them.
yeah ... rolling back to Opel Intellilink is easy.
it is just annoying, that hands-free calling and Google voice commands don´t work on Opel Insignia with Buick theme.
Gekko notovi redmouf Ahmed Ali MarcinFromSaturn Eatable
