EBCM and Cam Calibration files needed
hello i need the following calibration files, does anyone have them?
Thanks appreciate your help.
VIN W0LGT8GX9D1141168
Solved by Lyubomir Krastanov
  • Replies 15
  • Views 1.2k
    Can you share screenshot from modules part numbers (dps scan) need Base and End model.
    Ah, okay. Will get EBCM files later. I got BCM files already.
    BCM files attached, later will attach EBCM files as need to download them W0LGT8GX9D1141168 K9.rar
Here the Screenshots
thanks
BCM and ABS
you want EBCM and K109 Front Camera Module, but you give me End and Base numbers for EBCM and BCM
Yes, I know that. I don't need anything more for Camera 🙂
so you have your files?or need any other files for that VIN?
I only need the files from the BCM and EBCM
Thank you for the BCM files 🙂
EBCM numbers is not for that VIN and cannot obtain files
I just saw that you were looking for the EBCM for old VINs. Sorry my fault. I need the EBCM files for these Vin W0LGS6EN5C1067383
Only EBCM for this VIN or BCM as well?
Only EBCM
20 minutes ago, drstraleman said:
Only EBCM
your files attached
W0LGS6EN5C1067383 EBCM.rar
Thank you!!!
mechanix blocked echelon Programmer marcel_hack_guy hassan77h Adelin amazingjoey
