2018 Chevrolet Volt Used Power Inverter module
I have a 2018 Chevrolet Volt with a faulty Power Inverter Module, and for the replacement, I need to change the used Power Inverter module VIN and PIN possibly? I have GM DPS.
  • Replies 7
  • Views 1k
    Might be quick via SPS, need to check if mine allow me that car and can try to help you remotely.
It should be possible. Did you have both VINs? PINs?
I tried SPS and got an error message saying that the module was lock I believe, SPS wouldn’t finish the calibration setup. It then that I notice the VIN in the donor needed to be changed and so here I am.;)
I made a mistake, I have two Volts and I gave you the wrong one. Here's the Volt information that I need help with.
2014 Chevy Volt Used Power Inverter VIN change: I need help, I’m new and have a 2014 Chevy (1G1RF6E47EU161880) that I’m working on that needs a Power Inverter replacement. I have GM DPS now, but I need the files to edit the VIN in the used unit. I installed the replacement but quickly found that I couldn’t use it, in SPS it gave an error that the module was locked I believe, so I reinstalled the original module. I need some help. What do I need and how do I fix this issue?
collider bekatsilosani nwallace exc11 JackSullivan Artak Movsisyan Vahe OLEH Mikluha_Maklay Michalmiernik Arm M DoctorMac DPSuser Cutter Layne Bumgarner MV_auto GMcars krzakx
