SPS Car Backup
Hello everyone, is there a way to make a backup of all control devices in your car using Online SPS? If yes how? When I open my control devices, SPS reports that everything is already up to date and does not upgrade and therefore there is nothing in the Cahce folder. Thanks
  • Replies 7
  • Views 645
is possible, simple edit current files. Or share your VIN and might someone if have time can get you all files
I have SPS. I  need only he Desciption.  Have some one a Desciption? or is one here and get the Files for me?
Use VCI. If you expect someone to write you step by step how to do it, that will not happen. There was explanation from @Troy a while ago how to trick system and get your files. Make effor and find it. As well I say, share your VIN and someone might help. But to be asked to share your VIN few times will not help you.
I have all the files of my car of all ECUS. Simply, find a VIN like your car, and use it in SPS. SPS will download the files regardless of whether they are the same ones that are already programmed in your car. But you need use another VIN. If use your own vin, SPS can't start the download.
Hello, with the VIN (from another Car) works the download.  Only for Motor and TRansmission i can´t get the Software. Can someone help me. My VIN is: W0VBE8EH0J8017204
go wiht DPS or GDS2 and give me screenshot from module info page for both modules where you need calibrations
Hi,
Motor:
Endmodell-Teilenummer
12686384
Hardware-Teilenummer
12670934
Kennung Softwaremodul 1
12686385
Kennung Softwaremodul 2
55505303
Kennung Softwaremodul 3
55503092
Kennung Softwaremodul 4
55503108
Kennung Softwaremodul 5
55507731
Kennung Softwaremodul 6
55507721
Transmission
24284672
24285009
Teilnehmerkennung
*34VDYE
Diagnoseadresse Steuergerät
18
Diagnosedatenkennung
F06
24279785
Kennung Alphacode Softwaremodul 1
AA
55505284
Kennung Alphacode Softwaremodul 2
AB
55505285
Kennung Alphacode Softwaremodul 3
AB
55505286
Kennung Alphacode Softwaremodul 4
AB
Systemcode
And one File from the BCM:
Kalibrierungs-Teilenummer 10
39103927
F
bekatsilosani Capt Shane hassan77h Tyler Mygrant
