XML file programming IPC
Hi guys,
I'm looking if is necesary to change VIN in this section to my VIN when I'm trying to enable or disable some pages and warnings on IPC.
thank you for help!
<DidItem>
<ID>DID0090</ID>
<DidNo>0090</DidNo>
<DidDataIndicator>0090</DidDataIndicator>
<Name>DID_90</Name>
<Description>This DID contains the Vehicle Identification Number. It shall be write protected via security access and shall be impemented according to GMW 3110.</Description>
<DidLength>17</DidLength>
<DefaultValue>0000000000000000000000000000000000</DefaultValue>
<verifyIfSecured>false</verifyIfSecured>
<isCustomerData>false</isCustomerData>
</DidItem>
  • Views 731
  • It’s not necessary. If you bought Troy’s tutorial then you will understand what’s necessary.
mateok bondarrenko ABOMAZEN chicking Enterlan Kamilmichu DrJerry Buzz hassan77h mechanix SCAMMER Slein Eatable
