A11 - Programming fault
Hi, I was trying to load in a diffrent file with EU calibrations, then my module stopped responding.
I can't program the orginal files back now, tried with DPS and with SPS (i have an active subscription for my VIN) that's also failing.
Can the module be bricked? Or is there a way to bypass the erorr? Please see attached log.
ProgramLog.Txt
  • Views 606
  • The radio is on pin 1. Try again and post the log.  Set DPS diagnostic PIN to: PIN 1.
Thanks will try that now 🙂
Kanafin are you doing this on the bench or in the car? Did you get it to work?
Mikluha_Maklay PixelTheKWolf apetrushenko gsmik Jaydog wdse Adelin
