[Courses]: ▶︎ Learn how to activate features in the GM IPC Instrument Cluster using the GM DPS Tool
In this course, you will learn to manually activate or deactivate parameters/options in the IPC using the GM DPS tool. Note: some GM vehicles does not support this modification method.
Things you will learn
Change the VIN in supported modules.
Add or remove RPO codes using the GM DPS tool.
Activate the Speed Limit icon from the Sat-Nav Map.
Deactivate error DTC such as the Service messages displayed on the IPC screen by faulty Blind Spot side detection system modules.
Activate or deactivate the IPC Pocket Gauges.
Activate the IPC Turbo Boost PSI Pocket Gauge.
Activate the performance menus.
Course preview. A fully detailed online interactive course system, including a tutorial video.
  • Replies 8
  • Views 1.7k
I it the same as this back than?
Yes the new tutorial has the same info. In the new tutorial I show a new much easier way to activate or deactivate the parameters plus it has some new information.
Hello, Pcket Goudes works on Astra k?
Yes you can activate the gauge for Astra k that has the similar 8 inch IPC. I don’t know if that vehicle has the electrics for the gauge to function.
Nice i have the Oil Temp but that didn`t work (No Sensor).
What need i to put another Gauge on it?
The left gauge can only be set to off or oil temperature.
  • 4 months later...
Just an FYI.
The "View course" button seems to be broken.
Probably happened in the move ?
5 minutes ago, The Dewd said:
Just an FYI.
Thanks, I'll update now 🙏.
Thamer Mo jjagel alejandroruiz Jasper colibrig vavan DanN bondarrenko Enterlan madoobler notovi oltenasu marian Ahmadjon Rahimjanov PixelTheKWolf BabyLonLand Pasha Ehm_Gee aleks nik avkrug rollieollies
