Activating heated seats in a Bolt EV
Solved by Crocodile
Just now, Crocodile said:
What am I doing wrong? Even when I upload the "absolute factory" file from you via DPS, it bricks the car. It's probably something simple. image.png.a1c471bda3bc85dcd2771805d9dccd05.pngI press the "Program" button. Any settings perhaps?
I can almost bet it's a learn option.  Give me a few to go get the setup part.
  • Replies 36
  • Views 4.6k
Could my China clone MDI be faulty? Although I have used it for 5 years with SPS and GDS on countless cars without an issue.
No, you wouldn't have programmed successfully.  I'm convinced there's a learn procedure.  Just booting my stuff up to look.
Let me try to do the BCM Learn with SPS, I have the VIN paid for anyway.
Actually, that's even better.  Saves me some time 🙂
Yess! It worked! SPS BCM Learn unbricked the car, and the "park light on" went away.
Now I will install the HS file, then run another Learn.
Yeah, that's what I worried.  We should try and build a T4 app so you can skip having to login to SPS haha.  Save's time but then again, how often will you do this?
OKay, HS file is in, this time it did not require the BCM Learn (strangely enough). HS buttons did not appear.
Can you get me the files to program the A11 Radio? I think that will do it!
Thanks a lot for guiding me through this.
17 minutes ago, Crocodile said:
So there is no separate K74 HMI on the Bolt, so A11 radio is what we need to try, I think.
I realized that after too :).  Just have to run out for a bit but can get you it after
Thank you @codebuilder, it is with your invaluable help, I have now solved this challenge.
A11 Radio and BCM both needed to be reprogrammed with their heated seat software versions. Then BCM Learn had to be performed separately, in order to unbrick the car. And then clear all DTCs afterwards to turn off the CEL.
Adelin Enterlan Amplifier rickc
