2013 Cadillac XRS IPC boot loop
Vin # 2G61V5S31D9120155
The vehicle IPC is stuck in a boot loop. I have full communication with it and can program with sps but it will not accept update via usb. It shows PRND in bottom corner of the enhanced display ipc but does not indicate the gear its in. It will also randomly show the gauge animation then will reboot. No illumination on steering wheel and no heads up display. Any help would be appreciated!
  • Replies 11
  • Views 1.3k
    Reflash with sps2. Or request VCI from Techline with older calibration and explain them situation. Most of times they will help
Any dtc stored?
No dtc stored
Can u see what calibrations is loaded via gds2? Never see stuck in boot IPC.
SPS states correct calibrations are loaded.
GCI_Log.Txt
Idk if its possible to obtain virgin files for this ipc
is that speedo is original for your car or is retrofit/upgrade?
Original to car.
ill give that a try. thank you for taking the time
You don't have any wired bypass in your HMI system or anything?  Someone else was trying to do a USB update and it actually broke them from being able to do it.  Once they removed it, they were able to update the IPC.  I'm also assuming it's the USB update for your VIN as well?
I do not have anything intentionally bypassed or anything that I can see that would be in line of the hmi. I was able to complete the usb file transfer from sps for the hmi but fails on the usb transfer for the ipc after a few seconds. At this point I believe it is just a faulty ipc but with the screen booting and occasionally showing the cluster animation it make me believe it is a software issue instead of a hardware one
