Vauxhall/Opel Astra K 2017 Hmi 2.5 problems
Hello guys, maybe someone can help me.
Have replaced Hmi 2.5 unit with same part number, but it was removed from insignia 2018.
After Vin relearn  radio start working ,but no GPS signal on satnav and needs disable reverse camera , because not fitted to this car and every time in reverse gear blue screen coming on display.
What calibration file do I need to install to get those 2 problems fixed.
Thanks in advance.
o
  • Replies 10
  • Views 2.4k
    try this  hmi astra k.zip
    share your VIN to try to download your files
  • codebuilder
    codebuilder
    I can't download them for you but Lyubomir likely can :).  If you haven't updated the calibrations, it might just be in there and that simple.  There are some flags for different countries, etc.
Thanks in advance.
o
Do you have access to SPS?  I can't download for your VIN as I'm not in the same country but if you can download it, that'll fix it.  Otherwise, you could try some of Troy's that he's built as one may be close enough.  Otherwise maybe someone else here can help get them for you.  You can try the HMI files here, it won't hurt anything just might change some of the features.  They might actually turn everything on you need.
Hi. Thanks for getting back to me.  Have tried to reprogramming by sps hmi unit but only managed to disable reverse camera.  Still no gps signal on satnav
Is your antenna connected properly?  That's the only time I've ever seen it show that
 Hi, codebuilder I only replaced HMI 2.5 module behind speedo and all cables are connected.
Hi, Lyubomir Krastanov. Thanks for trying to help. Vin -  W0LBE6EC0HG131785
try this
hmi astra k.zip
@Kastis Can you report outcome?
Main Problem was faulty GPS antenna.
Ginocar Enterlan notovi Mantas Zandaravicius Opelinsignia1985
