CHEVROLET TRECKER 2 ,ONIX ECU BOSCH E64 EPROOMDA WIN yuq
Dps orqalu qanday qilib win kirgizsak buladi. JAVOB UCHUN OLDINDAN RAHMAT
  • Views 4.2k
    A bit hard to understand, but will try my best. So if you replacing ECU and need new VIN and PIN. First u have to know both (donor and target car VIN/PINs), then is simple. Can use any of DPS packages
Please use English even thru translator
ECU E64 win number is gone. How to enter winnj. Chevrolet onix and trekker 2
A bit hard to understand, but will try my best. So if you replacing ECU and need new VIN and PIN. First u have to know both (donor and target car VIN/PINs), then is simple. Can use any of DPS packages available here and reset/relearn or even buy PINs via VINs or use SPS. After that will need to reprogram ECU with correct calibrations, execute Setup and Configuration and learn keys. Good luck.
chicking zph666 chita_it Usbusmon Elmurod Avezov EUROTEAM2 mikkyrun Bek.33 Jose Herrera Mandriao Marcelo Espindola Rafet Truhnder Андрей Крылов Chiptuning Tashkent AutoStreetDiag hamelion CRISTIAN ORTIZ Joseane Valcanaia soj8961
