AUX not working after replacing the HMI
Hello Boys and Girls!
My car is Opel Insignia 2.0 CDTI Biturbo, MY 2014. The sound system of my car is BOSE. In order to use CarPlay and AndroidAuto, I replaced my HMI 2.0 with HMI 2.5, doing the necessary programming and updates on HMI 2.5. I then updated my silverbox for compatibility with the new hmi 2.5 (after replacing the HMI no sound could be heard when calling). Now everything works perfectly, but a problem occured: the AUX socket (probably) does not work  - when I press the media button below the display, with an external MP3 player on (which I used without problems before the silverbox update), it says "No media available", ie. can't find the player (AUX socket). At the same time the USB socket works without problems.
That's exactly the strange thing, that AUX and USB sockets are located on the same port...
Is the problem software or is it a matter of some settings?
I would be very grateful if you could give me some advice.
  • Views 1.4k
Software issue
Thanks for the reply, Lyubomir!
Can something be done to solve the problem? Is it just a matter of updating the current software with a specific file or do I need a complete new programming of the silverbox?
U have to get correct calibrations for your system and flash it(HMI). As well will require some Configuration to Radio and IPC.
