How to program HMI unit with original calibration files
On 9/25/2023 at 3:19 PM, Arbe_gtc said:
Your car have onstar?
Depending on whether it has onstar or not, the calibration that makes the microphone work is different. if you load a calibratios of a car with onstar, in a car without onstar, the mic stop working.
For SPS, search a VIN of insignia B you need and programm the HMI using this vin and will program OK
@codebuilder  Actually, as Arbe said, it is my vehicle. The original did not have OnStar. The HMI 2.5 I upgraded had OnStar. So there may be an incompatibility. If someone teaches me how to program and calibrate, I'll try it myself.
  • Replies 28
  • Views 3.1k
  • Got everything working after: - Updating firmware to HMI 2.5 Firmware file 84156714 via USB - Programming the HMI calibrations original to my car That's it. Also learned that the USB sti
  • Your car have onstar?   Depending on whether it has onstar or not, the calibration that makes the microphone work is different. if you load a calibratios of a car with onstar, in a car witho
  • As Lyubomir wrote, your best bet is to try the USB update then do the calibration.  When I encountered this, I had a European unit that I purchased off of eBay (same part number as your original) and
U need to use correct usb update file and then execute programming to hmi and ipc and radio and then configure all modules.
Please tell me a means of communication where I can reach you. I ordered VCXNANO. I can contact you when it arrives.
Sorry, I had missed that.  I had just fixed this same issue for Nasser.  It's a flag in one of the calibrations (can't recall off of the top of my head but I can find it).  I sent Nassar a file and the mic started working.  I'm happy to flip it if you send the calibrations to me.  I see you're waiting on a VCX though but I don't mind looking and updating the calibration for you.
The changes you want are in the country calibration.  There's a microphone config flag and a few Onstar flags.
DumitrescuGabriel chicking Robi_X Pasha RubenTX PixelTheKWolf Redsupra warriorpluto zecabg gsmik tan tan Tarzan BlackBoxTechnic slawcioo DrJerry ackalo Svbasta
