Need Astra-J and Astra-K calibration files.
Does anyone have access to an Astra-J and Astra-K?  I need these calibration files for both vehicles' EBCM, EPS, BCM and IPC.
I can't get these files using my insignia setup due to "Hardware Mismatch error."
Astra-K 2019:  W0VBE6ECXKG380514
Astra-J 2014:  W0LPF2EN8EG092081
Thanks.
  • Replies 21
  • Views 3.2k
    Give me 2h to emulate those cars and will provide you calibration files.
  • Part numbers for the VINS. W0LPF2EN8EG092081 IPC 13442458 BCM 13592590 EBCM (13384014) 39061712 W0VBE6ECXKG380514 IPC 39179176 BCM 13519643 EBCM 84102578
U need just Programming files or Setup and Configuration batch? Or both?
I only need the programming calibration files.
Is possible to have my file from sps if my old EPS module does not work if I look in tis2web.service.opel.com I see two file listed Capturedecranle2023-09-14a14_09.55(4).png.f149e330ef7aee22aad28710788b5f85.png
@Troy can’t find P/N for EBCM and EPS. I still can get calibrations but will not include Utility file and I presume is important for you. Just have no time to visit my local dealer to help me with P/N for these. If you can get them I will emulate modules and will download complete set of files.
if you can get me list of cals needed i can post them for you guys i ripped a few of the global dbs not sure i did opel what gloabal tis would they be on
@jeremy mccain VINs and required modules is in first post. I got BCM and IPC, but due cannot find correct part numbers cannot obtain EBCM and EPS files (cannot obtain Utility file).
W0LPF2EN8EG092081
IPC 13442458
BCM 13592590
W0VBE6ECXKG380514
IPC 39179176
BCM 13519643
EBCM 84102578
@rusty2009 need EPS as well or to point me where in EPC stay EBCM and EPS. I located IPC and BCM (they are easy)
1 hour ago, jeremy mccain said:
EPC?
Electronic Part Catalogue - EPC
@jeremy mccain looking for second hand parts not always help as no guarantee these part numbers is installed on these vehicles (VIN match)
i thought you were just trying to find a cross reference to what other vehicles or vins you could use to find the utility file
When enter VIN in SPS then select modules, SPS check for part number which should be correct for this VIN to allow you to pass and obtain calibrations. If you have wrong number, system will throw error for wrong part number and will not continue.
over here in US they use dif hardware numbers for same modules in different vehicles.  The LS ecm has about 50 hardware ids
@Troy P16_IPC_UDD_W0VBE6ECXKG380514.7z
Calibrations of UDD, maybe i can try to download the others you need of K.
i wll try in my car
That why I needed correct for every VIN. I just use Part number faker and swap module PN from my car to target one and download calibrations.
nicol MaxGood Adelin Rain kitsaras kobrak16 Jasper Axioma ABOMAZEN Arek bondarrenko ViCo2 Pablo blocked Robi_X tejiera alatka asd maczoka karolputowski mechanix
