GM Seed Key Generator
I am pleased to announce the release of the GM seed key generator tool.
This tool generates the seed key for all GM 5 and 2-byte seed electronic modules.
Note: To generate the correct seed key, you must input the module's seed and security algorithm code into the seed key generator tool.
The included "Read Me! Instructions.pdf" demonstrates how to determine a module's algorithm code. You can also use the GM DPS tool to determine the module's seed.
A helpful tool for advanced users who want to send commands to the modules manually.
Note: This tool is for advanced users. I do not offer any support regarding figuring out your module's seed and algorithm. Do not message me asking, as I will not reply.
This tool is locked to the PC hardware ID
After purchasing, you must install the tool and send a private message, including your PC hardware ID to @Troy  to receive your activation key.
How to receive your activation code.
  1. Download the tool from the downloads section.
  2. Extract the "GM Seed Key Generator.zip" to your PC desktop.
  3. Open the PDF file "Read Me! Instructions.pdf", read its content and follow the instructions.
You can purchase the tool from the link below.
  • Views 1.7k
Ediagforcars autorepair A61bk PixelTheKWolf mrfast Catracho stensin
