Add RPO codes
Hi i am new to DPS but i think i am trying to do something fairly simple. I just want to add an RPO code (DL3) to my BCM and door switch modules (DDM and PDM). I am assuming that i need to read/view the files from these controllers and then modify them and flash them back on. Is there any tutorial or quick breakdown from a high level how this works? I am an engineer and familiar with several programming tools so with enough info im sure i can figure the rest out...
  • Views 3.6k
This tut will explain how to use IPC xml files and rpo codes but if your adding new features to a module then expect to possibly need to either edit or replace some of the calibrations also..
is there a solid tutorial on how to edit xmls/add features? Im just adding the mirror power fold option, just one RPO. I can actuate the mirrors via Tech 2 i just need the feature in there to do it themselves.
do you know, what is needed to change to enable mirrors to fold automatically with locking the car?
notovi Gekko Savip_ DumitrescuGabriel ve_nico Teklock per.geras Jasper ABOMAZEN Troll Deryck jjagel StargateSilverado coolorado kitsaras Ranger clone Enterlan savke PixelTheKWolf Bill_haze
