2019 Cadillac XT4 Serial Gateway Programing Error
I am getting an error when trying to program the Serial Gateway module with SPS. It has 2 sides and the first side programs fine but the second side I get an error right as it is ready to finalize. E4423 error 5 at step 0, anyone know what might be causing this? Its frustrating because it was throwing an error, I don't remember for what and there was a bulletin on GM that said the module needed to be reprogrammed. Now it stops here and my dash is lit up like a christmas tree
  • Replies 11
  • Views 1.7k
Any way you could mock it up on the bench? Maybe interference from something on the car, or wiring?
From google,
  • E4491/E4423 – Programming Failed.
This error can be hard to diagnose, because it means that the application can communicate with the module but the it is unable to write all or part of the calibration due to an incompatibility. The most common cause of this is an aftermarket item being wired into the communication bus.
No I don't have a bench set up, I was hoping someone would be able to understand the line and trace information. I am sure it is another module in the car that it has to communicate with to complete the process just don't know what one.
is this the original ecu or replacement?
could you share spslog, maybe it help to understand
Do you have a MDI2?
If this car is Global B - there was a notice that some modules cannot be programmed without MDI2 (or equivalent) hardware.
This car is not Global B, Global B started 2020
GM models using the VIP architecture include (Global B):
Buick
2021-2023 Envision
Cadillac
2023 LYRIQ
2021-2023 Escalade
2020-2023 CT4
2020-2023 CT5
Chevrolet
2023 Colorado
2022-2023 Silverado 1500
2021-2023 Tahoe and Suburban
2020-2023 Corvette
GMC
2023 Canyon
2022-2023 HUMMER EV
2022-2023 Sierra 1500
2021-2023 Yukon
The timelines below for HS CAN Bus used on GM vehicles.
HS GMLAN … – Non SDGM - GMLANs accessible at the DLC
HS GMLAN … – Gen 1 SDGM – Infotainment isolation only, primary network testing still available at the DLC.
Gen 2 SDGMs – Not installed in any production GM vehicles.
HS GMLAN 2018 – Current Global “A” – Gen 3 SDGM - Complete network isolation.
CAN & CAN FD - VIP ( Global “B” vehicles) Select 2019 to 2022 models – VIP SDGM - Complete network isolation.
that car is 100% global a 5 byte.   have done 100's of them
programming error occurs for the following reasons
1- software mismatch of the dashboard control unit and BCM
2- mismatch of lag values in the firmware for updating
3 the vin code and karpas in the eeprom have not been replaced with the necessary configuration file \Production is Troy wrote in the topic about dashboard updates \ read this topic carefully.
Well finally getting back to this vehicle, kinda pushed it out of the way and moved on then had an unexpected personal issue. I just reprogrammed the instrument cluster and the BCM no problem, Side 1 of the gateway programs no problem at the end of programming side 2 I get the error it is frustrating. I am also noticing that I am unable to communicate with a lot of the low speed serial devices but that is likely due to the incomplete programming of the gateway.
exc11
