Insignia A udd ipc & Astra J bcm calibrations
Hi everyone, I'm looking to enable the TPMS on my udd Insignia A cluster (installed in an Astra J) along with enabling the front fog lights in the Astra J bcm.. fairly straight forward I think but I do need the calibrations to do it... would be great if anyone has them to share..? Details are..
Insignia cluster PN/ 23193607   VIN/ W0LGM6EM9E1016148  Warning Calibration...22922107 &  Overspeed & Biasing Calibration..23189177
Astra J bcm       PN/ 13591610    VIN/ W0LPF6ENXFG127616   Fog Lamp Calibration...13451349  +  Utility file..
Any help with any of those is greatly appreciated
Thanks....
Solved by WSOpel
  • Replies 15
  • Views 2.3k
3 minutes ago, WSOpel said:
TPMS Active
Thankyou vey much indeed... 👍
let me know if it work 😄
I'll give the cluster a try later this evening and let you know.... thanks again 😉
Perfect thankyou... 👍
Your Welcome
On 4/2/2023 at 10:09 AM, WSOpel said:
Your Welcome
Front fogs now programmed with your cals and working perfectly 🙂... Thanks again for the time and effort you've put into helping me get there...👍
Youre welcome
If anyone has a bcm calibration set for vin W0LPF2ES6EG057626 those would help a lot with my next project.. most of the files are already in the archive above very kindly posted by @WSOpel , the files which differ slightly are below.... Many thanks
13 minutes ago, WSOpel said:
Thankyou so much yet again.... can I send you some beer tokens in return 🙃..?
Just now, WSOpel said:
That's great thankyou so much, made some good progress so far with the other files and these should hopefully help answer the last part of the puzzle 🙏 🙂
E-Ing-X20XEV bondarrenko ABOMAZEN jjagel stensin nev3r chicking Camelot hassan77h Ahmed Ali Lyubomir Krastanov
