The DPS tool and retro fitting parking assist in 2022 GMC sierra Denali
This DPS did the job, I have 2022 GMC sierra Denali , here in the states GMC sold many 2022 vehicles without modules for "Park Assist" do to the chip shortage.....they promised a "Retrofit" the modules have been available for months but GM won't update the SPS data files until they are ready to start retrofitting. I purchased troys XML tutorial and was able to capture the build files for the IPC using a different truck and VIN with SPS ...I had to click "override " at all the warning promps and sps failed to write but I got the calibration files..and only got 1 build file..Build record.bld and the XML file.XML....i changed the .bld extension to .txt and using notepad i changed the vin to my vin#
my first write attempt failed, but after I checked all the global A settings and global A with object detection it completed the write with no failed or error messages and my park assist functions perfectly...thumbs up..
  • Troy changed the title to The DPS tool and retro fitting parking assist in 2022 GMC sierra Denali
  • Views 1.7k
Did car came with module or you fitted one
no it did not come with K182 park assist module, and IPC was non functional for park assist do to RPO 00Z ....the K182 modules are now available but GM is slow to update there calibration files
Nice job man well done!!
Check vehicles from beginning of MY22 to get correct calfiles. My observation that the MY22 vehicles what were built in 2021 had correct Park Assist Control Module.
What car does have side Park Assist? (XML config does not work, so it must be Cal)
Anderson Fonte regloops Adelin snaggs Capt Shane notovi penguin4170 radi A61bk etegtman
