Buick Regal 2015 HMI update screen
Hi, do somebody knows which update is it looking for? I turned On my car few days ago and this was the screen I saw, this happens a few times during the day, rear camera works but does not shows the guide lines, bell from proximity sensors also works, even the Buick logo appear when start the car but no multimedia...  black screen.
Is it possible that someone of you can share the USB files to update this HMI?
Thanks.
  • Replies 21
  • Views 2.6k
If the Regal has the HMI 2.5, you can use this file below or use GM SPS service to update the HMI's firmware,  then use GM SPS service to program the HMI, to restore the Buick Regal theme and settings for that vehicle.
That issue you're having was also solved in this topic.
Hi Troy, in my case is HMI 2.0, is there a similar firmware for it? Thanks for your answer.
I don't know if SPS has firmware for HIM 2.0. You can check by selecting in SPS "human machine interface", then select the "USB file transfer" option.
Hello Hugo, can you share your VIN (you can do it privately via PM too)?
I may have the files you need.
I try to get you exact calibration, need vin and hardware ID
Hi, after many time I found a person that has the DPS software and a VXDiag interface (I'm not expert on this), is helping me to load the files you sent me, but at 99% of the process the DPS retuns an error, so what is the suggestion for this? HMI still not working, please your comments, here an screenshot of the error:
hmi 2 or hmi 2.5?
These were the files I was able to provide to Hugo at the time..
42 minutes ago, Hugo Galindo said:
hmi 2.0
try this HMI2_REGAL_2015_IO6.zip
And for io5 (no nav integrated)
HMI2_REGAL_2015_IO5.zip
Hi, thanks for your help but still not working, at 99 percent of the programming process it returns an error.
There is a difference, with files that pupu14 (Hugo_Regal_2015_HMI.zip) shared me I'm able to use the audio using the controlls on the steering wheel, like in the next picture, with files shared arbe_gtc (HMI2_REGAL_2015_IO6.zip) only appear the message "Audio deactivated" and no audio output.
Any idea how to fix the problem of the 99 percent?
Try with different version of DPS (older/newer, does not matter).
If you have this option - try programming with different J2534 scantool.
i think your problem is the HMI need the software, not the calibrations.
can you share the part number of your hmi?
Hi, here the information:
Part                  Number
652029760    7310400000000X
NG 2.0 HMI
ist like this? 23493425?
Hi, so is it possible to get the sofware for my HMI (23228496), thanks you!
Gracias!.
sorry, i cant get it.
you can read the Final Model Part Number with GDS2?
MarcinFromSaturn
