Hi, can I change the vin for my E92 or restore it to VERGIN?
  • Replies 6
  • Views 2.2k
Hi, it's not possible to change VIN nor PIN in any GM ECM using DPS at the moment unfortunately.
Hptuner is best option for it! I did many with Hptuner
You can use IO terminal
What happen, why was the feature removed?
On 18‏/11‏/2022 at 09:53, dmyo said:
يمكنك استخدام محطة الإدخال والإخراج
Yes, I have an IO terminal and I read the file
Here you will go to this website and browsethe information on your VIN Decoder can reveal a lot about your car's history. We'll help you decode the meaning of your VIN numbers, and give you key points to consider in terms of buying, selling or trading any vehicle.
veeeeight John Stevens Redsupra Martin Mendez alaa_bastaki benkej tonypre Kirk Holland A61bk Rrmjn Cutter ltuning
