LC7F LC7S Intellilink R4 LG SilverBox Radio ASM-Receiver VIN Change UNLOCK Insignia-B Astra-K.
This DPS file will change the VIN in the LC7F and LC7S SilverBox RADIO ASM-RECEIVER that comes installed in some insignia-B, Astra-K and other GM vehicles.
The file instructs the radio module to learn the VIN that's stored in the BCM module. This file is useful for when needing to installing a used LC7F or LC7S radio module into a GM vehicle.
  • Replies 10
  • Views 5.5k
3 hours ago, martijeff said:
Hello, how should I save the file that I will receive from you
You download the file after purchase, then load the file into dps and click the program button.
I have a LC7F with lcd from Opel Mokka.
Is ok for this ?
Thank you in advance
Is ok for this ?
Hi, yes this file will unlock that radio.
Hi I keep getting “Error Occured FERGANA Programming
Hi, the DPS version you're using does not support 5-byte seed. You need DPS version 4.46, 4.51 or 4.52.
Hi I got version 4.48. Can you send me the link please
  • 6 months later...
  • 7 months later...
On 26-10-2023 at 21:42, IVANCHO said:
Hallo, ik heb een vraag, in een GMC Acadia is mijn radiomodel een LC7F, LCTS heeft een camera aan de achterkant, het is mogelijk om ook een camera op dezelfde radio aan te sluiten .
Can you help me with weer i need to plug the rear camera to the LC7S SILVER BOX. OR DIAGRAM
alatka asd jackbonys Rtn Rt Piotr Michalski Enterlan GMcars Kamilmichu Yodai Forex Forex A61bk
