How to change VIN in GM ECC-HVAC Electronic Climate Control module using GM DPS
Changing the VIN in a used ECC-HVAC Electronic Climate Control module is vital for folks who want to recycle used secondhand GM electronic vehicle modules.
Using this custom DPS file, you can achieve that.
Watch the video to see the process
ECC-HVAC VIN change for most GM 2-byte seed modules.
  • Views 1.4k
Great work as always!
  • 4 months later...
I upgraded my hvac system from single zone to dual zone climate control on my silverado and this file worked perfect!!
Hi,
Will this work on vauxhall astra 2017
exc11 IstvanKiraly Enterlan lbarbar zamich85 marcel_hack_guy tungnv93pt Like-Minded Fool
