IPC PIN change
Without a pin code change in a used IPC, BCM, EBCM, and SDM you won’t be able to program those modules via GM online SPS service using the vehicle’s original PIN.
This DPS file can change the PIN CODE in most GM Global-A 5 bytes EBC ABS modules.
Important
  1. In order to change the PIN code in a used GM module, you will need to know the PIN code that’s already programmed/stored in that module. Without knowing that PIN code, you cannot change the PIN code in the modules using DPS
  2. You have to wait 12 minutes for the PIN code programming procedure to be completed by DPS.
Methods for knowing the PIN CODE stored in a used module.
Connect the used module to DPS, then use the "get Controller Info" option to know the VIN stored in the module.
You can then use this VIN to PIN service to know the PIN CODE stored in the used module.
VIN to PIN Service
Watch this video to see the process.
https://cameraloops.ru/uploads/videos/gm_pin_code_change.mp4
IPC PIN CODE Change DPS file, 2 bytes seed
IPC PIN CODE Change DPS file, 5 bytes seed
IPC PIN CODE Change Cadillac Escalade 2018 DPS File, 2 Bytes Seed
IPC PIN CODE Change Astra-J 2015 DPS File, 2 Bytes Seed
View full gm info
  • 11 months later...
  • Views 3k
so if you change a vin in the cluster, ecm, bcm and not the pin are you saying you can not update the module anymore and/or add a key? and can you use aftermarket tools to add keys or because of the pin mismatch will you not be able to add keys?
U need to change bcm and ecm at minimum pin code or immo will kick off and will prevent car to start
blocked Enterlan DrJerry
