How to change PIN CODE in GM's Vehicle Modules using GM DPS
For some time now, I've been trying to figure out the PIN CODE change option using DPS with no success. I had some free time today, so I had another go at the PIN CODE puzzle. I solved the puzzle after drinking two cans of RedBull and thinking a bit. Changing the PIN CODE in GM vehicle modules is now possible using the DPS tool. This option is excellent for folks who want to recycle used secondhand GM vehicle electronic modules.
Without a PIN code change in a used IPC, BCM, EBCM, and SDM, you won’t be able to program those modules via GM online SPS service utilising the vehicle’s original PIN.
Important
  • To change the PIN code in a used GM module, you must know the PIN code already programmed/stored in that module. Without knowing that PIN code, you cannot change the PIN code in the modules using DPS
Methods for knowing the PIN CODE stored in a used module.
Connect the used module to DPS, then use the "get Controller Info" option to know the VIN stored in the module.
You can then use this VIN to PIN service to know the PIN CODE stored in the used module.
VIN to PIN Service
Watch this video to see the process.
BCM PIN CODE Change DPS file, 2 bytes seed
BCM PIN CODE Change DPS file, 5 bytes seed
BCM PIN CODE Change Cadillac Escalade 2018 DPS File, 2 Bytes Seed
IPC PIN CODE Change DPS file, 2 bytes seed
IPC PIN CODE Change DPS file, 5 bytes seed
IPC PIN CODE Change Cadillac Escalade 2018 DPS File, 2 Bytes Seed
IPC PIN CODE Change Astra-J 2015 DPS File, 2 Bytes Seed
EBCM ABS PIN CODE Change DPS file, 2 bytes seed
EBCM ABS PIN CODE Change DPS file, 5 bytes seed
EBCM PIN CODE Change Cadillac Escalade 2018 DPS File, 2 Bytes Seed
EBCM PIN CODE Change Corvette 2014 DPS File, 5 Bytes Seed
SDM AirBag PIN CODE Change DPS file, 2 bytes seed
SDM AirBag PIN CODE Change DPS file, 5 bytes seed
View full article
  • Views 1.9k
Yes Troy. You never fails to amaze me. I needed pin change with DPS. Keep up the good work. Thanks
Happy Fun GIF
Good job!
  • 3 years later...
collider jjagel veeeeight tobiasp Techpiotr tungnv93pt mechanix dogwulf Danielb Enterlan apetrushenko bniedzwiedz0 vuonchim Tech PixelTheKWolf Redsupra tonypre ElectroHobby Iasi notovi Galaxie Ahmad Zabalawi
