SDM AirBag Vin Change With GM DPS
Changing the VIN in GM SMD AirBag modules is vital when recycling a used module. You can achieve this by using this DPS file.
These files only work with GM Global-A vehicles.
Play the video to see the process.
GM Global-A 2 byte seed file
GM Global-A 5 byte seed file
  • Views 2.1k
Hi Mr Troy..
I need change PIN CODE on SDM and EBCM silverado 2019, I think is 5 byte. Have file to do ?
46 minutes ago, MANNYM1987 said:
Hi Mr Troy..
Hi, at this moment I can't change PIN in the module using DPS.
On 7/16/2022 at 4:13 PM, MANNYM1987 said:
Hi Mr Troy..
Yes I can now change the PIN in those modules.
Ferd Monge Volodymyr Ratushko Edgar Garay Autosys mrfast Ahmed Naser Carl Rollinson ViCo2 Hemilton Cheng Modulos
