GM Radio module theft lock removal
  • Replies 70
  • Views 6.4k
  • Yes vin change files will work on 2014 vehicles.
  • Last_Captain
    Last_Captain
    Vin is stored in fasia and radio unit of this type of radio unit, both should match with bcm
  • pistnbroke
    pistnbroke
    Can you post or send me your tuner calibration to take a look at... we were able to convert a Chevy Malibu radio to EU a few weeks ago.. maybe the same process..
34 minutes ago, vladimius said:
Iob system?
Do you have radio and hmi module too?
13 minutes ago, vladimius said:
I replaced hmi from 2.0 to 2.5, now I want to flash the radio on eu frequencies and Ukraine language
Need flash both, radio and hmi.
When you post here the calibrations I can make a packages for you
1 hour ago, benkej said:
Потрібна флеш-пам'ять, радіо та HMI .
Коли ви опублікуєте тут калібрування, я зможу зробити пакети для вас
For HMI 2.5 I have already assembled and programmed. Need help with radio)
radio_regal_2015.zip
Ok, I gonna do it for you, but if you already made hmi, you have to have Russian language in cluster and in the middle console too
On 25.09.2023 at 11:49, benkej said:
Гаразд, я зроблю це за вас, але якщо ви вже зробили hmi , у вас також має бути російська мова в кластері та на середній консолі
I have about 20 languages in hmi. Russian and Ukrainian are there
Try and report. You have to choose Low-Speed CAN-BUS. DPS Diagnostic Pin: 1 and the radio adress is $80
2015 Regal Radio.zip
No reply?
What u try to do there? If u have ready archive, just programm it
I don't understand what you do.
You have to upload it only.
Don't touch the archíve.
Here is the instructions:
You have to choose Low-Speed CAN-BUS. DPS Diagnostic Pin: 1 and the radioadress is $80
Select archive and upload it.
I made more than 30 cars without any problems with those radio file
5 minutes ago, benkej said:
Я не розумію, що ти робиш.
Ви повинні лише завантажити його.
Не чіпайте архів.
Ось інструкції:
Ви  повинні вибрати Low-Speed CAN-BUS.  Діагностичний PIN-код DPS  : 1 і радіоадреса  коштує 80 доларів США
Виберіть архів і завантажте його.
Я зробив більше 30 машин без будь-яких проблем з цим радіофайлом
The archive you provided gives an error
14 minutes ago, Lyubomir Krastanov said:
Що ти намагаєшся там робити? Якщо у вас є готовий архів, просто запрограмуйте його
I want EU radio waves
I know and made it for you.
What kind of error getting you?
1 hour ago, vladimius said:
Does not work....
Change zip name to the same name as .tbl file inside.
I rebuilt your archive and everything worked. Thank you very much !!!
9 hours ago, vladimius said:
Does not work....
Never change the archive name!
Yes, the archive name was different as the .tbl name inside. Only one thing to do rename the arch to match the tbl name
How would you add EU languages to these vladimius' calibrations? I have similar one and wondering how to do that.
ViCo2 jarrod early Enterlan gsmik aboturky modx
