GM Radio module theft lock removal
GM vehicle Radio unlock. Remove the Theft-Lock using the GM DPS tool.
Harman NFO3, INFO3.4, INFO3.5, INFO3.6, INFO3.7, INFO3.8 CSM MY19, MY21 SiriusXM GM Radio HMI Unlock Vin Change With DPS, remove the theft lock.
HMI 2.5, HMI 2.0 and radio unlock. Remove the Theft-Lock with the GM DPS tool.
For European cars/cars that use the SilverBox Radio module.
For USA cars/cars that use the satellite radio module.
ID7SF Silverbox RADIO ASM-RECEIVER LG Electronics. Chevy Chevrolet Spark 2019, 2020, 2021, VIN Change With DPS
LC7S VIN Change, Silverbox RADIO ASM-RECEIVER LG Electronics Insignia-B, Astra-K
LN7S-B VIN Change, Silverbox RADIO ASM-RECEIVER LG Electronics Insignia-B, Astra-K
Denso Ten Radio FT0108A 84691615 Unlock Vin Change With DPS
GM Denso Radio 23180744, Theft Lock Removal, radio Unlock with GM DPS
GM Panasonic Radio Model: GA-130-COLR-NT and GA-130-COLR-NS, Theft Lock Removal, radio Unlock GM DPS
IL7SF, IL7SB Radio, LG SilverBox Radio ASM-Receiver VIN Change UNLOCK, Silverado etc
GM Panasonic Radio theft lock removal, Chevrolet Cruze, Orlando, Cobalt, Radio Unlock with GM DPS
View full gm info
  • 6 months later...
  • Replies 70
  • Views 6.4k
  • Yes vin change files will work on 2014 vehicles.
  • Last_Captain
    Last_Captain
    Vin is stored in fasia and radio unit of this type of radio unit, both should match with bcm
  • pistnbroke
    pistnbroke
    Can you post or send me your tuner calibration to take a look at... we were able to convert a Chevy Malibu radio to EU a few weeks ago.. maybe the same process..
Can vin change files for the older radios be made..? sent pm with more details..
Like to know as well
File is for Global A only
Its a 2014 Global A car I wanted a file for...
To be correct I can use this on an 2014 Malibu to unlock the theftlock on the radio? I just got paid today and I'm ready to buy something from this site before I go to sleep😁also which file do I purchase? I see about four above.
I would need to know which radio module or HMI was used in the 2014 Malibu.
This is the one
Silverbox US (Cadillac CTS 2014) -> any idea how to change FM frequencies from US to EU?
Cadilac CTS were sold in eu, use their calibrations. Silverbox doesn't use cadilac, it uses SiriusRadio.
What we found before was changing to the EU tuner calibration corrected the frequency issue but lost RDS information and the EU calibration still had to be edited before dps would accept and flash it.. maybe a full set of calibrations would of acted different but the solution in the end for that one was to edit the US tuner calibration to correct the frequency issue, credit to @DarkDiver which also then kept the other calibrations original and also has the RDS info working..
I didn't know about that. Could you change  Biuck encore tuner calibration  to EU?
I'd be happy to try for you if you want to send me your files over...
Did you manage to change Buick Encore tuner calibration to EU? My original calibration is 94540048. What cal number should I upload to unit?
The original US calibration needs to be edited, PM me your original file and I'll take a look for you...
Can't send PM. Ill post here.
94540048.bin
I've sent you a file to test... Let me know how you get on..
Works. Thank you very much.
Is there a possibility to add EU languages?
Your welcome.... and yes send me your existing Language calibration over...
Language cal
94783426.bin
Which default language would you prefer.. Polish..?
Yes please
ViCo2 jarrod early Enterlan gsmik aboturky modx
