help cd500 navi - insignia 2009
Hi ,
I have bad cd 500 navi in insignia 2009 and wish change with unit from oter car
I bay unlock file for vin change and  use DPS tool for programing but not sucess ...
Maybe i make some wrong is it possible some help ?
i use MDI interface  and have comunication with car , read info working but when tray programing CAL file not pass.
Is it need some adjust is DPS tool before programing ?
is it ok procedure step by step :
1. vehicle architecture = GM global A
2. sybtype = golbal A
3. Protocol = gmlan
4. diagnostic pin = 1. 83.3kb
5. get controler info / select MDI interface
6. ecu adres ID = 11  ???   or need change
7. request method = standard  ? or need change
8. read info and ok
9. selec calibration zip file and load
10. program
Then i have error ...
  • Replies 4
  • Views 1.6k
Maybe your interface is the issue. You may need to buy a VXdiag nano GM interface, that one works great with DPS.
Strange , i use original MDI interface which working on last gds2 perfect , win tech2 on win 10 all working .
Which version DPS prefer  ?
I bay allso and last 4.8 version and will tray.
Use dps 4.46 that one works fine.
Ok  I will tray .
Its not need  some adjust  in controler info tab  for insignia 2009
ECU adres ID / 11 is set
request metod / standard
Also not need to write first  VIN in BCM like HMI modul ?
In protocol and comunication seting  is ok to be select  :
1. vehicle architecture = GM global A    or    Other
2. sybtype = golbal A    or   Standard
3. Protocol = gmlan
Then load  unlock zip file and program unit  ?
Zeca
Greg_or stensin zecabg
