How to change the VIN number in GM K43 electric Power steering control module using DPS
3 hours ago, Troy said:
Yes, that's correct.
Here is the list of all the GM ECU IDs
It is 5 byte seed! Just tested on an Equinox. Would the VIN change file work for both Malibu and Equinox provided they are all 5-bytes? Thanks much!
  • Replies 29
  • Views 9.1k
  • good jop i bought it and wating new  😀
  • Which car is it? Can you pm me the vin number?
  • I don’t know as this file was created for insignia Buick Regal. If the files doesn’t work and you can provide the utility file for that module I can create a dps vin file of it.
Yes, one will work for both.
Hello there. I´m trying to get the info for a 2013 Chevy Malibu that customer changed IPC, but i´m getting "Read Error" and i cant get any info with DPS.
Coulg you share the settings to use so that i could make connections and get IPC info?
I will need to change VIN on this dash so that i can run the SPS programming to the car.
Or, is it possible to read and modify info from IPC eeprom / memory manually?
EDIT:
I was able to do connection on this. It turns out that Tatrix OpenPort 2.0 doesn´t work on this for IPC.
For reading the IPC with DPS, set the DPS diagnostic pin to:1 and the ECU ID is: 60
To program the used IPC via GM SPS service, you will need to change both the VIN and the PIN. Yes, you can manually change the VIN and PIN via the IPC EPROM chip.
More info at the links below.
  • 2 years later...
I have paid for both 2 byte and 5 byte. None of them worked for me. It´s a S10 Steering wheel. Tried in 2 different vehicles.
Firestars Dog mohammed exc11 Techpiotr ahmedalbblaiazi Lulu Gilbertosaju Todor Stoilov Mikluha_Maklay lsxtuner mastery Pinballben F Brock Johnson LS-Juan Fire Phoenix SergSanich maccat Aleksandr dsog Yepremyan
