How to change mileage in GM's cars using GM's DPS
HI all
I have the DPS 4.44 but I still have the same problem , I have a 2015 GMC Sierra SLT & I did swap the IPC to the Denali also I change the VIN to my car VIN .
what shall I do ?
  • Replies 57
  • Views 11.9k
  • ECU ID. https://www.cameraloops.ru/gm-ecu-id-list/     table {border: 1px solid #000000;border-collapse: collapse; margin: 0 auto; padding: 0px;table-layout: fixed;min-width: 100%;}tabl
  • No those files only works with the radio in the attached photo. For Escalade CUE or Sonic/Cruze MyLink it should be possible once DPS can get ecu info from those car radio. However, I would need calib
  • Opel_driver
    Opel_driver
    It works great. Thanks again👍🏻
12 minutes ago, -ashkan- said:
HI all
what shall I do ?
Try using the file with the vehicle’s original IPC.
Troy my friend
U mean that I should put the old IPC & try it ?
Edited by -ashkan-
Yes. Try the old IPC. Both the IPC and BCM must be compatible, shares the same VIN and communicating for the mileage correction file to work.
Troy my friend
I sent you a private message.
I did get the PM , I'll check it & I'll inform U
On 3/7/2024 at 11:20 AM, -ashkan- said:
HI all
what shall I do ?
Did you get to figure it out. I saw an issue similar to this when i had BCM replaced for a 2017 Chevy Malibu. I had the original IPC and communication wasnt getting established between the BCM and IPC. So you might have other issues taking place that needs to be fixed. You might want to check if there is any error codes that shows up on a scanner.
  • 9 months later...
On 7/17/2022 at 12:23 PM, aaronprg said:
Its only changes bcm's mileage. Original mileage stored in ecm's eeprom. Is there any way to change ecm's eeprom
Yes the the mileage in the ECM emulated eeprom can be changed with special software and hardware, all in the hardware/software costed me 300+
DanielGuzman Adelin Shifty jjagel tssvnc Mikluha_Maklay Andrey Semiannikov tema Lulu vuonchim Tech SnugMyg hootydavis Enterlan RV Lemos doubleg Teklock Jukkis Encrypted Owner Hasanain Joudah Jasper
