Request for IPC Equinox CAL File 84336579
Hot First Post
Hello team,
I would greatly appreciate it if someone could help me.
I am looking for CAL file 84336579 for the IPC Equinox software.
Unfortunately, it is no longer possible to download this file from SPS because it has already been replaced with a newer version. As a result, my IPC is currently not working.
If anyone has this CAL file or knows where I can obtain it, I would be very grateful for your help.
Thank you in advance.
Solved by Xumoyun Server
  • Replies 10
  • Views 64
Give us a VIN number
Original files.
partnum = 84336579.01
partnum = 84208810.02
partnum = 84266960.03
partnum = 23384799.04
partnum = 84208811.05
partnum = 84209823.06
partnum = 84209826.07
partnum = 23384809.08
New files IPC dead with this software files
Blob name: 23132548.00
Blob name: 84475403.01
Blob name: 84208810.02
Blob name: 84266960.03
Blob name: 23384799.04
Blob name: 84208811.05
Blob name: 84209823.06
Blob name: 84515344.07
Blob name: 23384809.08
Oh, well i don't have it but strange that your IPC doesn't turn on?
As those calibrations came from sps..
Try on 33.3kbps pin. not 83.3kbps. Some interfaces don't like to use that speed because of buffers etc. (vxdiag and scanmatik too included)
You are absolutely right. When I used 83.3 kbps, the process could not even pass 27 01.
After switching to 33.3 kbps, the seed was calculated successfully, but I still received an error during the flashing process.
Now I’m trying to see SPS info for each VIN from 2016, 2017, and 2018 Equinox vehicles to see if I have any chance of finding the original CAL file.
Topic cloced. Probelm was that i did reporgram with IGN ON. need to be IGN OFF. But sps not alert
  4. hassan77h
  5. wofy
    +wofy
    6
Xumoyun Server regloops Adelin Jasper
