Calibration request
Hello my friends, I'm in a complicated retrofit scenario. I'm adding an IPC instrument panel from an Onix LT (VIN 9BGKT69V0HG10525) to an Onix Joy (VIN 9BGKL48U0KB21164). I managed to match the VINs normally using the dump file in HXD. However, during the initial file reading, the configuration DIDs got confused in the bin file, and some functions on the panel don't activate at all. The available menus are oil lifespan, language selection menu, and unit selector, besides average speed, range, average km/l, and stopwatch. But I saw in the DIDs that it's possible to add battery voltage and other functions to this IPC, and I saw that doing this with DPS would be much easier, but we don't have access to SPS in Brazil, making everything more difficult. That's why I really needed the cabling files for the BMC and the IPC for the retrofit. I can provide feedback to the community, thank you all.20260515_195514.heic20260515_195448.heic
Dump_FINAL_gravar.bin
Solved by Bruno Anacleto
  • Views 238
For the sake of fun with the BCM, I would like to activate the S3U fog light profile, the dimmer which is not functional, and for the IPC, activate the compatible functions. Thank you all very much.
Cleberson Santos mcOreos E-Ing-X20XEV palyt regloops Bruno Anacleto Jasper alatka asd Troll Deryck ABOMAZEN jjagel tan tan AsUmachine dfyznu Andrey Semiannikov Mikluha_Maklay nev3r Adelin tobiasp mechanix
