Upgrading Corsa E
Hello everybody, I‘m new to this forum but not new to car modification/upgrading.
I want to do some mods to my 2015 Corsa E and want to know which tutorial/s I need to do what I want.
So first I want to swap my Engine ECU. I have the B14NEJ 100hp which is the same engine like the B14NEH 150hp, only with decreased power. So I ordered a B14NEH ECU. Now I want to change VIN and PIN.
Second is I have an OPC IPC which I want to get working in my car. So I have also to change VIN and PIN.
And third I want to upgrade the normal halogen lamp to LED lamp in the headlights. When I do this a fault code pops up in the IPC. How can I remove this messages?
Thank you in advance for your answers.
  • Views 654
I think your injectors will not support necessary fuel delivery.
that is easy
need to be disabled from xml file
Hi, the injectors are the same like the B14NEH. That would be no problem.
The problem is how to change vin and pin. For you it´s maybe easy, but at the moment not for me.
And without changing VIN and PIN I can´t get an XML file.
I changed VIN and PIN. But I again can’t see mileage. What I‘m doing wrong?
kos9979 exec Markov Campean-Craciun Cristian
