tis2web
hi all can you guys check its tis2web not work anymore to check modules calibration part numbers here is the link its not opening for me  thank you..
TIS2WEB.SERVICE.GM.COM
Solved by Troy
  • Replies 4
  • Views 4k
  • Use  TIS TIS2WEB.SERVICE.OPEL.COM   Or use DPS archive creator tool, which automatically creates a DPS archive. No need for tis2web.
  • you can register in acdelcotds https://www.acdelcotds.com and login. then you can click on resources and select SPS Calibration Information
Use
thank you troy for your quick solution / help ... thanks
I use Opel SPS information for "old" vehicles.
Hlk Sadro ViCo2 nicol Marcel G. Rose Cartechnology maczoka ABOMAZEN Jose Nava Teklock fennecsaab Francois Spies artur minasyan stensin Alain Jasper TheNerdGuyLulu Rusnet1 zph666 nev3r alatka asd
