Insignia B Cluster in a Astra K
i have the digital Cluster from an Insignia B in the Astra K. It works fine.
On the left side i have the Oil Preassure but it don´t work.
Is ther a Chance too change this?
Solved by bajad
  • Replies 11
  • Views 2.5k
To change what? Or change this indicator to other or make it to show pressure ? If there isn't oil pressure sensor on engine installed then it will not work.
The left is oil temp
In the K, it is not working. Maybe a missing sensor. In my case, I deactivated it
ok and another didn´t work?
You need a special Module for that
Ok what Modil i need?
canny is the module
ok what is that ? Wher can i found that?
  • 4 months later...
Hello, Which Modul is it, an where can i by this. Or hav someone a new Firmware to solved the Problem?
Canni module. Some russian lad selling it
  • 2 years later...
Has anyone solved the problem, or can provide contact information for someone who does?
  • 8 months later...
Is there now a solution for retrofitting the oil temperature?
M Ch Dariusz Mokrzycki syciu marcel_hack_guy blocked Enterlan Arbe_gtc pupu14 tobiasp bajad Opelinsignia1985 exc11 ABOMAZEN Opelfan DumitrescuGabriel Vauxhall_Mark raku_og Arcani Thomas Crosbie Camelot
